Guten morgen,
gibt es die Möglichkeit eine TV-Tuner-Stick an der QNAP zu installieren, die auch von Plex unterstützt wird?
Wer hat ein solches System am laufen?
Danke für eure Rückmeldungen
Viele Grüße
Dan
Guten morgen,
Viele Grüße
Dan
Hi Dan,
this is the English forum …
I can say that from looking at the .qpkg of Plex on my qnap the Tuner Service is there. I do not have a supported stick, so I can not confirm it works. The .qpkg packages run in some kind of root, but as other applications inside the .qpkg package can access my USB devices I am sure there should be no issue… I would be more worried about kernel modules, because some of the supported devices require a custom driver - and I do not see how install on a QNAP. You might want to ask at the qnapclub.de forum for more information or maybe someone uses your required setup and can confirm …
What would work for sure as worst case solution, is that you run Plex inside a docker container and hand the device into the container, that way Plex will find it.
Cheers
Alex
Danke für den Link.
