The Queens Funeral is about 21gB (admittedly a big file) and I cannot seem to get it to import into my Plex TV shows. It is in the correct folder, it is named correctly according to TVDB, has banner and covers in the folder and the file will play fine with Infuse. Is there a file size limit or some factor that I don’t know about?
Folder and file are named as you stated “The State Funeral of HM Queen Elizabeth II”(The State Funeral of HM Queen Elizabeth II - TheTVDB.com).
FileBot could not find it using TVDB but renamed it with banner and cover using FileBot ‘Auto’ mode.
Update. I put the file in my ‘Movies’ folder and it showed up just fine. Thank you. This does however bring up a once-in-a-lifetime opportunity to ask ‘what if the database gets it wrong?’ This particular BBC live television broadcast was indeed an exception (it wasn’t a three hour 4K Imax movie)–it was just a very long TV show. So…shouldn’t there be a process or a flag or boxes with crosses to tell the database that this really is a TV show?
I did move the file to Movies and it’s fine. Based on your comments, I copied it back to TV Shows and it doesn’t show up. This has been an educational experience however and I appreciate your help.
