Hi everyone,
I recently started using Plexamp after years of using Spotify. Over the past few months I’ve been building my own music library (currently around ~200GB). I’ve organized playlists and now mostly listen to my music through Plexamp. Most of the time I listen to the same playlists repeatedly, and occasionally I use DJ mode or the automatic radios generated by Plexamp.
After a few weeks of use, I noticed that my mobile data usage is significantly higher than it was with Spotify. During February 2026, Plexamp used about 11.54 GB of mobile data.
This is understandable to some extent because Plexamp streams the original files from my library (FLAC, MP3 320 kbps, MP3 128 kbps, etc.), whereas Spotify uses its own streaming formats. So higher usage makes sense and it’s not really a problem for me personally since I have an unlimited mobile plan, plus an additional 40GB for Europe and the US when I travel.
However, this made me look more closely at Plexamp’s caching settings, and this is where I’m not sure I fully understand how things work — or whether there might be something I’m missing.
My current settings are:
Wi-Fi queue: 5 tracks
Mobile queue: 5 tracks
Cache size: 32 GB
Here is how I think the system works.
Let’s assume the cache is completely empty. When I start playing a playlist, Plexamp loads the current track and the next five tracks to ensure smooth playback. When the next track starts playing, Plexamp loads the next five tracks again — but since four of them were already cached, only the sixth track needs to be fetched. This process then continues as a rolling queue.
In that scenario, if I go back to a previous track, it shouldn’t need to be downloaded again because it should still exist in the cache.
The part I’m unsure about is what happens after closing Plexamp.
If I close the app and come back later, then start the same playlist again from the beginning, it seems like the first tracks are downloaded again from the network. That makes me wonder whether the cache is being cleared when Plexamp closes.
If that’s the case, I’m not sure I understand the purpose of having a 32GB cache (or even up to 128GB). It seems unlikely that a normal listening session would fill that entire cache in a single session.
Downloading playlists doesn’t seem like the right solution for my use case. My server is accessible about 99% of the time, so network availability is not really an issue. My goal is simply to reduce unnecessary data usage. I imagine it could also help with battery usage if previously played tracks were reused from cache instead of being downloaded again.
I also have a question about downloads vs normal playback.
If I download a playlist using the download feature, and later start listening to that same playlist in the normal Plexamp interface (not from the downloads section), will Plexamp play the local downloaded files, or will it stream the tracks again from the server?
I’m asking because I previously experienced something similar with Plex video. Before a train trip I downloaded a TV series to my device. I started watching episode 1 from the downloaded files, but when I pressed “next episode”, Plex launched episode 2 and it started buffering once we entered an area with poor network coverage. I had to manually open the downloaded file or switch to airplane mode to force Plex to use the local copy instead of trying to stream it.
So overall I’m wondering:
Does Plexamp persist the cache between sessions, or is it cleared when the app closes?
Is my understanding of the rolling cache mechanism correct?
In what real-world scenario would a large cache (32–128GB) actually be filled and useful?
If a track is downloaded, will Plexamp automatically use the local file during normal playback?
Thanks!
