Queued library scans hanging
Server Version#: 1.25.5.5492
I have 3 music libraries containing the same tracks, but at different bitrates. I normally add new tracks to the appropriate folders and immediately manually scan all 3 libraries. The scan for the first library starts, and normally the other 2 queue up and do their thing in order, but Sonic Analysis also starts when the first library is finished.
What’s started to happen is when Sonic Analysis kicks in, the scan for the next library hangs. I have to cancel the scan for the library it’s hung on, and then re-scan. This behavior started sometime in the last couple server updates.
Possibly related to
https://forums.plex.tv/t/plex-doesnt-refresh-libraries/775772/
https://forums.plex.tv/t/library-updater-does-not-manually-update-library-media/772681/
Although since yours is specific to Music libraries it may not be.
People have reported that the last version that didn’t exhibit hangs is 1.25.3.5409, in case you want to roll back
Thank you for the reply and links.
Hopefully the devs will be able to figure this out soon. I’m not sure if I’m going to roll back or just wait it out. It sure is a pain, though!
I started seeing this today for the first time. Running 1.25.6, which the above links suggest should have resolved the problem…
1.25.6.5577 did indeed fix the problem I described.
I think what I’m seeing is this:
