Hi
it is with all my Streaming Webradio channels. f.e SHOUTcast, Bay FM 99, Plex Podcast. Just a few minutes ago I tested a new fresh Installation. The same result.
Yesterday morning I had a connect. but just once and it tok very long to connect. Do you want any logfiles?
It should take just a second to conntect to the stream, right?
if it works fine with your site, than it Points to connectivity. Mybe in new release same Network Settings are different.
Can you tell me, if the stream is downloaded by the PMS, or does RPI directly downloading.?
How about Name resultion?
The error-message is starting with “failed GetDirectory …” In wich loggfile is the full errormessage logged. i can not find it on \rasplex\log files.
meanwhile I found the right logfile. I Could extract a sniplett with logged errors and posted it here http://pastebin.com/hMtHDQR0
In this sample it takes nearly 2 seconds to download an XML document.
Later GetDirectory failed to fetch data from plexserver://b93… with Result 500.
What does this mean? Where to look next?
by the way. Did user, Password changed on new Releases? plexuser, ra… does’nt work for me to ssh in with putty.
Username ist root. with Password ra…
Considere update credential info on. How to report a bug · RasPlex/RasPlex Wiki · GitHub
Yes, you are right, it is not an persistent problem.
_Sametimes _channel do work. Sametimes but only _sametimes _Errors like this kann be found in plugins.log:
2015-08-29 20:13:14,746 (e3c) : CRITICAL (core:572) - Exception (most recent call last):
File “bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/components/runtime.py”, line 843, in handle_request
File “bundles-release/Framework.bundle-dist/Contents/Resources/Versions/2/Python/Framework/handlers/base.py”, line 111, in call
TypeError: MainMenu() takes no arguments (1 given)
I am connected with Ethernet. But my PMS is running a a virtual machine. The host is big enough.
It may be an timing problem.
I checked all usual Network stuff, Ip, dns and so on. next Thing can be WhireShark. But I do not understand enought what to search.
Yes I can confirm: It’s happens on PHT to! I just installed on an old and slow Netbook with Win10 PHT an do see the same error? Should i know Switch over this thread to the PHT Team or the PMS Team ?
Or stay with you
