Random movies playback
Hi
I have a strange behavior or openPHT 1.7.1 when I choose play on a movie it play any movie randomly.
When I use either the web interface of plex or Ipad interface it works correctly, so it is definitely openPHT.
I tries AEON NOX Plex Black and openPHT theme without any difference.
I uninstalled it and reinstalled it still the problem remains.
Any idea of how to solve this ?
I’ve only ever seen this when the cache is corrupted and the media ID’s don’t line up. Then it’s a matter of restarting OpenPHT and usually that clears it up.
Since you’ve uninstalled/reinstalled, you should really start from scratch by deleting/renaming your existing openpht data directory located here:
Windows: %APPDATA%\OpenPHT (C:\Users\[USERNAME]\AppData\Roaming\OpenPHT)
WARNING: This will reset all openpht / skin settings and you will have to go through initial setup again …
Thanks benjaminwolf
I deleted the data file in the mac libraries and reinstalled it again.
It is now working thanks a lot :slight_smile:
