Randomly not working since the update
Server Version#: 1.41.7.9823
Hoping someone can help. I have started to have issues with Plex since the latest update.
My server is running on windows server 2022 and I am streaming on my local network on a Windows 11 computer.
I will start watching something on the windows 11 pc and it will stream fine, but at some point the plex disconnects from the server. The media continues to play fine but when it finishes it will show as only partially watched. Then when you go to play anything else it will just spin the yellow circle and never play.
When I go to the physical server and try to play directly on that it does the same thing it will load like it’s buffering but never plays.
Only work around I have found is stop plex media server on the server, reinstall the latest version from plex and restart the server. After this it will work for either a few hours, days or just one watch.
Any clues or advice ?
Have a video of the log IDK if that helps at all
Does your server go to sleep? There’s a long running bug where the connection fails after your machine fits to sleep. Keep it from sleeping and you won’t have this issue.
