Server Version#: 1.32.1.6983 x64
Windows 10
Intel 15-10500 / 16GB RAM
Hello everyone! First of all thank you for any help.
I hope you can excuse me, but I am using the translator for this situation
I am having problems with the network in Plex, I attach images and the registry
As you can see in the photos, the connection to the server is completely lost, windows is working perfectly.
I have updated the drivers, but I can’t find the possible error.
Anyone with any possible ideas?
thank you so much!
Plex Media Server Logs_2023-04-30_22-22-50.zip (3.6 MB)
UP!
Hello again!
I have done multiple tests.
-update windows
-Update to the latest version of Plex
-Delete all windows updates
-Downgrade various older versions of Plex
-Reinstall windows without updating
All tests lead to the same result
Around 10pm - 11pm Plex stops working however the service is still running.
I have to restart the process manually for it to work again.
I am currently using version 1.31.1.6733 where I have given up testing
I have seen other threads related to the same problem but with no apparent solution.
All help is appreciated!
A cordial greeting, Ricardo.
I have updated to the latest version1.32.1.6999 and the problem continues.
I attach the log with the new version of PMS
Plex Media Server Logs_2023-05-14_18-13-02.zip (4.4 MB)
Thanks again.
When do you have Plex scheduled to do routine maintenance here?
This graph you posted is showing a remote stream. Is there actually a remote stream running outside your network here?
When this happens what is your CPU usage?
