Hi @Craigusus,
I followed your guide step by step.
At the ‘Setting up Plex’ point, I installed Plex Media Server on my Pi as I’m wanting to run everything on that.
After installing PMC, I just continue on with the setting up of Plex.
When setting up Plex I saw the Sony CXD2880 tuner and went with that one - that was a mistake and went back and added the IP address of my Pi manually with port 5004.
This then took me onto the channel list where it listed all of the pre-scanned channels. It then wanted me to enter my post code and then at this point wouldn’t allow me to continue on.
I decided to go back a couple of steps but then found that I couldn’t then see the tvhProxy tuner any more.
I checked the service was running, which it was.
I’ve looked at the log for tvhProxy and can see that Plex is prodding it when I click the ‘Connect’ button:
Nov 10 15:20:23 TVHeadend systemd[1]: Started A simple proxy for Plex and Tvheadend.
Nov 10 15:20:28 TVHeadend python[1348]: ::ffff:172.20.10.9 - - [2018-11-10 15:20:28] "GET /discover.json HTTP/1.0" 200 410 0.005727
Nov 10 15:20:28 TVHeadend python[1348]: ::ffff:172.20.10.9 - - [2018-11-10 15:20:28] "GET /lineup_status.json HTTP/1.0" 200 205 0.004279
Nov 10 15:20:28 TVHeadend python[1348]: ::ffff:172.20.10.9 - - [2018-11-10 15:20:28] "GET /discover.json HTTP/1.0" 200 410 0.004361
Nov 10 15:20:28 TVHeadend python[1348]: ::ffff:172.20.10.9 - - [2018-11-10 15:20:28] "GET /lineup_status.json HTTP/1.0" 200 205 0.004304
But that results in nothing happening.
If I browse to the discover.json endpoint I get the following:
{"BaseURL":"http://172.20.10.9","DeviceAuth":"test1234","DeviceID":"12345678","FirmwareName":"hdhomeruntc_atsc","FirmwareVersion":"20150826","FriendlyName":"tvhProxy","LineupURL":"http://172.20.10.9/lineup.json","Manufacturer":"Silicondust","ModelNumber":"HDTC-2US","TunerCount":6}
If I do the same for lineup_status.json endpoint then I get:
{“ScanInProgress”:0,“ScanPossible”:1,“Source”:“Cable”,“SourceList”:[“Cable”]}
So, I can see it’s definitely running, just that something has gone a bit pear-shaped.
I’m going to try (if I get chance today) to remove tvhProxy and re-install it.
The problem is that I can only do this when on the boat (with UHF booster) as we don’t have a TV aerial at home!
