rasplex (0.3.0/0.3.1?) playing channel causes warm reset
Some background.
I was running rasplex 2.1 and trying to play a channel, Kelby Training, which did not work until I purchased and install my MPG2 License after that everything worked very nicely.
I upgraded to 3.0 using the bz2 zip file scp'd to /storage/.update and that all worked nicely.
The issue:
Now I can not play kelby training videos. When I try, rasplex reloads the User Interface, not a complete reboot.
also I have two MPEG2 Files episode 3 and 4 or The Legend of Korra season 2 which do not play smoothly the splutter and stutter and then freeze in the opening credits. Though I had not played these files under 2.1 so do not know if this is a newly introduced problem. Can I go back to 2.1 using the same upgrade method I used to go to 3.0
The reason this post is labelled 3.0/3.1 is I installed 0.3.0 but when I ssh in to the unit it says 0.3.1
Logs attached
edit: I guess the system autoupdated since 0.3.1 was released. I think I will disable auto updates :)
Downgrade to 0.2.x should be possible using the same steps.
EDIT: Btw.: Auto-update from 0.3.0 to 0.3.1 has just fixed some bugs.
