RasPlex 9.9.17 - fixes iOS and android remote issues
If are willing to file a bug report https://github.com/RasPlex/RasPlex/wiki/How-to-report-a-bug then i'm pretty confident that we can get you up to snuff. 1080p is working flawlessly for most people, probably has something to do with your network setup.
Devs - have you seen the post regarding the new PHT 1.0.8.
https://forums.plex.tv/topic/56516-plex-home-theater/?p=549242
Seems like they have fixed a number of issues that people are having with 9.9.16, 9.9.17 and 9.9.18.
Regards
Regards
They have, see 0.9.9.18 release announcement on Facebook.
"RasPlex *experimental* build 9.9.18 is ready.
It’s a fairly minor update, but it fixes another major network flooding issue seen by some users, and includes PlexHT 1.0.8 which is hot off the presses."
After an hour of testing it seems to handle 720p DTS high bitrate via HDMI passthrough, handles 1080p DTS on same.
Set up using MyPlex PIN, waited for pre-caching to finish, set my HDMI passthrough, timezone and format.  Browsing seems pretty snappy, better than before I think.
I'm running 9.9.18, fixed iOS remote but still having network flooding issues using wireless. Grinds my whole network to a halt. Wired connection is fine.
I just wanted to report that with 9.9.18 the remote was indeed functional again. However, I was getting choppy playback. I reverted to 0.3.1 and playback is fine again.
Play back is fine with me on wired and the remote works great. Just getting network flooding over wireless connection so everything stops working.
Hi all
It's a great news !
And it's work fine !
But I have no sound, at all.
I have tested my Pi on another TV, it's ok. But on my second TV no sound.
On the previous release, I had no remote but I had sound.
I'm going to downgrade on 9.9.17 to see if it's ok, and I'll let you know.
Ok, my bad.
It was my TV. It's just work on the HDMI 2 port.
Sorry :)
Please try 9.9.19 to see if it resolves any issues https://forums.plex.tv/topic/96779-rasplex-9919-fix-preplay-huge-perf-improvements/
