So I’ve managed to get plex working over my college Internet, including from my server to mobile (wired to wireless local). The issue I have is getting my pi connected to the Internet, because the WiFi here uses enterprise (EAP) to authenticate users. Is there a configuration file on the SD card I could edit to contain said info?
Have a look at this http://testsite.openelec.tv/forum/124-raspberry-pi/75758-connect-to-a-public-wifi-with-eap-loghin you have to have access to another Linux machine to get it working.
Regards
OK… so I’m getting closer. The network config file is definitely changing things, but I’m still getting a failure, connman settings is outputting a very helpful “failure=failed-connect”.
Could this be an issue with the certification file? I moved over the .crt generated by my laptop when I got connman to connect to the network there…
Try this for inspiration http://openelec.tv/forum/88-wlan/55397-wpa2-enterprise
Regards
Yeah, that matches the config file I created. It was pulling the correct hex SSID and all from the given info in the wifi-settings. I think I’ve got a driver issue. Thanks for your help anyways.
