Rasplex MP4 H264 Error
Hello,
I have the first version of the raspberry pi running the current 0.3 system on a class 10 sd card.
Plex Server is running pretty well.
But when going to the movie library and starting one movie it seems like the pi does nothing and some seconds later it throws the error that it won't be able to play the file.
The movies were compressed with handbrake into a mp4 file with h246.
Is this a common error or do I have to buy another codec or is the holy solution something else.
Please respond as fast as possible! Thank you anyways
please post some details of these files. Use a tool like MediaInfo and post its output.
Regards
Kivas
What are you searching for.
These are Dvd's compressed with h264. File is an .mp4.
Anamorphic in handbrake was set to strict.
If you need further information write again!
have a look at the Mediainfo yourself - you'll see there is far far far more details to it than what you are giving.  Without detailed info, the best answer you can be given is "your files are incompatible in someway"
For Example;
General
Unique ID                                : 25310696722345234523453542003223885592121009 (0x2345234523525223451)
Complete name                            : Blah.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 59.2 GiB
Duration                                 : 3h 55mn
Overall bit rate mode                    : Variable
Overall bit rate                         : 36.0 Mbps
Movie name                               : BLAH
Encoded date                             : UTC 2012-02-01 13:25:18
Writing application                      : mkclean 0.8.6 o from libebml v1.2.3 + libmatroska v1.3.0 + mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                          : libebml2 v0.21.1 + libmatroska2 v0.22.1
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 2 frames
Format settings, GOP                     : M=1, N=10
Muxing mode                              : Header stripping
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 3h 55mn
Bit rate mode                            : Variable
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio #1
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : MA / Core
Mode                                     : 16
Format settings, Endianness              : Big
Codec ID                                 : A_DTS
Duration                                 : 3h 55mn
Bit rate                                 : Unknown / 1 509 Kbps
Channel count                            : 7 channels / 6 channels
Channel positions                        : Front: L C R, Side: L R, Back: C, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 24 bits
Compression mode                         : Lossless / Lossy
Title                                    : Lossless
Language                                 : English
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : DTS
Format profile                           : ES
Mode                                     : 16
Codec ID                                 : A_DTS
Duration                                 : 3h 55mn
Bit rate mode                            : Constant
Bit rate                                 : 1 509 Kbps
Bit depth                                : 24 bits
Compression mode                         : Lossy
Stream size                              : 2.48 GiB (4%)
Title                                    : 3/2+1
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #3
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Format profile                           : Dolby Digital
Mode extension                           : CM (complete main)
Codec ID                                 : A_AC3
Duration                                 : 3h 55mn
Bit rate                                 : 192 Kbps
Channel count                            : 2 channels
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 323 MiB (1%)
Title                                    : 2/0
Language                                 : English
Default                                  : No
Forced                                   : No
Menu #1
00:00:00.000                             : Chapter 00
00:04:08.748                             : Chapter 01
00:06:10.828                             : Chapter 02
00:14:44.967                             : Chapter 03
00:17:06.608                             : Chapter 04
00:19:17.948                             : Chapter 05
00:23:07.094                             : Chapter 06
00:23:58.311                             : Chapter 07
00:27:09.044                             : Chapter 08
00:28:03.181                             : Chapter 09
00:31:38.229                             : Chapter 10
00:35:45.518                             : Chapter 11
00:38:17.878                             : Chapter 12
00:41:47.796                             : Chapter 13
00:50:49.755                             : Chapter 14
00:58:19.412                             : Chapter 15
01:00:40.178                             : Chapter 16
01:02:48.306                             : Chapter 17
01:08:05.998                             : Chapter 18
01:12:41.732                             : Chapter 19
01:24:17.343                             : Chapter 20
01:25:41.636                             : Chapter 21
01:27:34.332                             : Chapter 22
01:30:45.523                             : Chapter 23
01:32:30.586                             : Chapter 24
01:34:31.040                             : Chapter 25
01:35:57.042                             : Chapter 26
01:37:02.316                             : Chapter 27
01:38:43.959                             : Chapter 28
01:41:14.818                             : Chapter 29
Menu #2
01:46:34.208                             : Chapter 00
01:47:17.000                             : Chapter 01
01:49:46.858                             : Chapter 02
01:54:53.415                             : Chapter 03
02:01:31.604                             : Chapter 04
02:04:11.722                             : Chapter 05
02:06:48.170                             : Chapter 06
02:08:25.726                             : Chapter 07
02:12:08.490                             : Chapter 08
02:14:34.469                             : Chapter 09
02:18:24.074                             : Chapter 10
02:23:03.645                             : Chapter 11
02:30:25.336                             : Chapter 12
02:35:58.586                             : Chapter 13
02:37:18.457                             : Chapter 14
02:40:26.728                             : Chapter 15
02:42:11.458                             : Chapter 16
02:43:02.134                             : Chapter 17
02:46:36.223                             : Chapter 18
02:52:58.605                             : Chapter 19
02:54:35.660                             : Chapter 20
02:58:00.781                             : Chapter 21
02:59:45.928                             : Chapter 22
03:05:48.415                             : Chapter 23
03:07:13.500                             : Chapter 24
03:07:48.243                             : Chapter 25
03:10:17.768                             : Chapter 26
03:12:49.753                             : Chapter 27
03:17:28.239                             : Chapter 28
03:19:54.594                             : Chapter 29
03:24:39.879                             : Chapter 30
03:25:32.431                             : Chapter 31
03:26:12.972                             : Chapter 32
03:28:16.762                             : Chapter 33
03:30:46.620                             : Chapter 34
03:32:26.303                             : Chapter 35
03:34:50.447                             : Chapter 36
03:43:46.733                             : Chapter 37
What tool did you use?
I took some screenshots on windows.
Format                                   : MPEG-4
Format-Profil                            : Base Media / Version 2
Codec-ID                                 : mp42
Dateigröße                               : 1,55 GiB
Dauer                                    : 2h 9min
Modus der Gesamtbitrate                  : variabel
Gesamte Bitrate                          : 1 710 Kbps
Kodierungs-Datum                         : UTC 2014-02-27 12:45:28
Tagging-Datum                            : UTC 2014-02-27 13:11:37
Kodierendes Programm                     : HandBrake 0.9.9 2013052900
Video
Format : AVC
Format-Profil : High@L4.1
Format-Einstellungen für CABAC : Ja
Format-Einstellungen für ReFrames : 4 frames
Codec-ID : avc1
Codec-ID/Info : Advanced Video Coding
Dauer : 2h 9min
Bitrate : 1 130 Kbps
Breite : 720 Pixel
Höhe : 428 Pixel
Bildseitenverhältnis : 2,40:1
Ursprüngliches Bildseitenverhältnis : 2,40:1
Modus der Bildwiederholungsrate : konstant
Bildwiederholungsrate : 25,000 FPS
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : progressiv
Bits/(Pixel*Frame) : 0.147
Stream-Größe : 1,02 GiB (66%)
verwendete Encoder-Bibliothek : x264 core 130 r2273 b3065e6
Kodierungseinstellungen : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
colour_primaries : BT.601 PAL
transfer_characteristics : BT.709
matrix_coefficients : BT.601
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format-Profil : LC
Codec-ID : 40
Dauer : 2h 9min
Bitraten-Modus : variabel
Bitrate : 192 Kbps
maximale Bitrate : 253 Kbps
Kanäle : 2 Kanäle
Kanal-Positionen : Front: L R
Samplingrate : 48,0 KHz
Stream-Größe : 178 MiB (11%)
Sprache : Deutsch
Tagging-Datum : UTC 2014-02-27 13:11:36
Audio #2
Format : AC-3
Format_Settings_ModeExtension : CM (complete main)
Format-Einstellungen für Endianess : Big
Codec-ID : ac-3
Dauer : 2h 9min
Bitraten-Modus : konstant
Bitrate : 384 Kbps
Kanäle : 6 Kanäle
Kanal-Positionen : Front: L C R, Side: L R, LFE
BitDepth/String : 16 bits
Stream-Größe : 355 MiB (22%)
Sprache : Deutsch
Menü
Codec-ID : text
Dauer : 2h 9min
Bitraten-Modus : VBR
Video Files get played by using the Plexbmc plugin for Xbmc.
It has to be a new / old bug according to what I think!
Btw: The lastest 9.20 version wouldn't even install on my 256mb pi.
