jjrjr1
1
Hi
Anyone played with RasPlex??
I have created two different SD card images of RasPlex. Version 1.0.01 and 1,0,03 from Rasplex.org…
Neither one will filly boot.
Both chips start up but hang on a multii color sort of fog screen.
Any Idea what I am doing wrong?
John
system
2
Check you are using the correct file there is one for the RPi1 and one for the RPi2/3
Regards
jjrjr1
3
Hi
Thanks for the reply.
I am on a Rasp Pi 2
I tried every Rasplex I could find including both at Rasplex.com
No Joy…
Sooo…
I installed Ubuntu 15 on the Pi…
Now I just run Plex Web using Firefox…
Works fine.
Cheers
John
system
4
jjrjr1
5
I tried that version 3 time from different sources including the official Pi site.
Just won’t boot on my Pi2 B+
system
6
Is it an Rpi2 or an RPi1B+? There is no RPi2B+.
If it is really an RPi1B+ then use the RPi image, not the RPi2, if you are not sure try the RPi image.
Regards
