Rasplex won't boot
I’m trying to get Rasplex to run on my RPi3 Model B. I installed it on a class 10 SD card using GetRasplex.exe When I put the sd card in the RPi and apply power nothing happens. I know it’s not the Pi because I have successfully installed and used Raspbian just fine. Any suggestions?
P.S. Here is an screenshot of my GetRasplex settings:
is this really the right version?
Don’t select and image file manually.
If the builtin downloader in Getrasplex doesn’t work,
download and flash this RasPlex-1.8.0.148-573b6d73-RPi2.arm.img.gz
I’m not sure if it’s the right version or not. I was following this tutorial: https://www.linux.com/learn/turn-raspberry-pi-3-powerful-media-player-rasplex
It said “choose Raspberry Pi 2 from the model number and version 1.6.2 (or the latest version) from the RasPlex.” So that is what I did.
try the image file I linked to.
It worked! You’re my hero! Tytytytyty
