Rasplex Volume
Using Rasplex latest release through Home Cinema Amp with HDMI. All good, but the Rasplex output volume is stuck at -12.7dB when I hit the volume on my remote. The volume indicator comes up on the screen, but it refuses to move up or down. I’d normally just have this set at 0dB and use the amp for the volume. Not reducing my enjoyment, but any help appreciated!
Sounds like it’s being controlled by the CEC Adapter. Your TV or Home Cinema remote maybe controlling this volume. You could try disabling the Peripherals if you don’t want to use CEC.
