readTags for tvshows (python)
Hi, I'm trying to modify a script to take into account the tags (writers/directors) for series episodes so I looked into the tvdb plugin and found what seems to be the function that handles it:
  def readTags(self, element, list, name):
    try:
      el_text = lambda element, xp: element.xpath(xp)[0].text
      tag_text = el_text(element, name)
      if tag_text.find('|') != -1:
        tags = tag_text.split('|')
      else:
        tags = tag_text.split(',')
  tags = [tag.strip() for tag in tags if len(tag) > 0]
  list.clear()
  for tag in tags:
    if tag not in list:
      list.add(tag)
except:
  pass
but the result is not what I expect as it seems the core of python is not agreeing with this :
2014-07-03 16:37:26,329 (-8d07950) :  CRITICAL (core:556) - Exception while loading code (most recent call last):
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/core.py", line 550, in load_code
    self.init_code = self.loader.load(self.init_path, elevated, use_xpython = Framework.constants.flags.use_xpython in self.sandbox.flags)
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/loader.py", line 47, in load
    code = self.compile(str(source), str(uni(filename)), elevated)
  File "/share/MD0_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/code/loader.py", line 52, in compile
    return RestrictedPython.compile_restricted(source, name, 'exec', elevated=elevated)
  File "/root/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/RestrictedPython/RCompile.py", line 115, in compile_restricted
    gen.compile()
  File "/root/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/RestrictedPython/RCompile.py", line 68, in compile
    tree = self._get_tree()
  File "/root/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/RestrictedPython/RCompile.py", line 59, in _get_tree
    tree = self.parse()
  File "/root/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/RestrictedPython/RCompile.py", line 56, in parse
    return niceParse(self.source, self.filename, self.mode)
  File "/root/Library/Plex Media Server/Plug-ins/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/RestrictedPython/RCompile.py", line 38, in niceParse
    compile(source, filename, mode)
  File "/root/Library/Plex Media Server/Plug-ins/XBMCnfoTV.bundle/Contents/Code/__init__.py", line 244
IndentationError: unindent does not match any outer indentation level
So I just don't get why the function is giving me an error without even been called once in the script. I guess I am missing something but really can't see it. If anyone could point me on how to make the tag reader working without throwing any error that would be very nice. Thanks.
http://stackoverflow.com/questions/492387/indentationerror-unindent-does-not-match-any-outer-indentation-level
You might have spaces instead of tabs somewhere
/T
Thanks. That did indeed remove the error about the identation.
Just now I have other errors... Well...
LOL, but still here  ;)
