@killthevideostar said:
thanks, @sa2000.
i know forums are support based,
but i assume logs contain private info.
either way, logs, attached:
The database is corrupt
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - SQLITE3:0x7fff5e2df260, 11, database corruption at line 59437 of [fc49f556e4]
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - SQLITE3:0x7fff5e2df260, 11, database corruption at line 59479 of [fc49f556e4]
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - SQLITE3:0x7fff5e2df260, 11, statement aborts at 14: [DELETE FROM 'main'.'fts4_metadata_titles_segdir' WHERE level = ?] database disk image is malformed
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - SQLITE3:0x7fff5e2df260, 11, statement aborts at 9: [insert into metadata_items (library_section_id,parent_id,metadata_type,guid,hash,media_item_count,title,title_sort,original_title,studio,rating,audience_rating,rating_count,tagline,summ
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - Exception inside transaction (inside=1) (../Library/MetadataItem.cpp:869): sqlite3_statement_backend::loadOne: database disk image is malformed
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - Exception inside transaction (inside=1) (../Library/Episode.cpp:187): sqlite3_statement_backend::loadOne: database disk image is malformed
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - Exception inside transaction (inside=1) (../Library/MetadataItem.cpp:2682): sqlite3_statement_backend::loadOne: database disk image is malformed
Feb 08, 2017 12:01:51.623 [0x7fff76269310] ERROR - Exception assimilating media item in Colgate Comedy Hour/Season 01: sqlite3_statement_backend::loadOne: database disk image is malformed
The database file is "/Users/plex/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db"
See if it can be repaired
https://support.plex.tv/hc/en-us/articles/201100678-Repair-a-Corrupt-Database
Other option is to look for a backup to restore from, see
https://support.plex.tv/hc/en-us/articles/202485658
You should also check the disk drive for any issues
