Building up a new B+ Pi (already happy with my B version RasPlex Pi) and want to get the best bang for my buck. What size do you recommend for the MicroSD card?
I know the specs say at least 2GB but will extra storage make any difference?
A 4Gb Class 10 MicroSD is sufficient, no point in spending money on storage as it won't be used.
Regards
Regards
Thanks for the prompt reply Ned. :)
Wanted to double check…is this still the rule of thumb?
4GB Class 10 MicroSD is still the recommended size for Raspberry Pi 2/3?
Many thanks!
That’s right.
Regards
4Gb cards are now harder to find that 8Gb. Both are fine though.
8GB cards are almost for free… its insane… 6$/5€ for a 8GB card… I bought a 16GB though… 12$/10€ …
