There is a lot of data in your logs. Logs only cover about 3 hours of time. Unfortunately I have no clue why your show does not show in your library. I see where it started recording and got to 100% and request was made to stop the recording, then nothing that I saw until over an hour later when I see it destroying the metadata so guess it was deleted for some reason but I don’t see why in the logs. Perhaps a Plex Employee can chime in here and look @keithah @BigWheel. Pasting log entries I found related to the Matlock show below.
Jul 12, 2017 09:59:00.894 [11120] DEBUG - DVR:Grabber: Starting operation for ‘Matlock - E3 - The Legacy’.
Jul 12, 2017 09:59:00.895 [11120] DEBUG - Activity: registered new activity 131b43a3-1342-4ea4-9541-85dfcafac258 - Recording
Jul 12, 2017 09:59:00.895 [11120] DEBUG - DVR:Grabber: HDHomerun starting a media grab on device device://tv.plex.grabbers.hdhomerun/10532295 tuner 0.
Jul 12, 2017 09:59:00.896 [11120] DEBUG - DVR:Subscription: Resolved subscription to library item ‘Matlock’ (179770)
Jul 12, 2017 09:59:00.914 [11120] DEBUG - There were 1 top-level paths for Matlock.
Jul 12, 2017 09:59:00.915 [11120] DEBUG - DVR:Grabber: Saving recording to W:\TV-Shows.grab\894f5daa98f9fd9616ec222d8b36034aa9452e93
Jul 12, 2017 09:59:00.915 [11120] DEBUG - HTTP requesting GET http://192.168.10.111:80/lineup.json
Jul 12, 2017 09:59:00.946 [11120] DEBUG - HTTP 200 response from GET http://192.168.10.111:80/lineup.json
Jul 12, 2017 09:59:00.947 [11120] DEBUG - DVR:Grabber: Going to record for 3720 seconds, final URL is http://192.168.10.111:5004/auto/v12.2?transcode=none
Jul 12, 2017 09:59:00.947 [11120] DEBUG - DVR:Grabber: Setting timer to stop grab of ‘Matlock - E3 - The Legacy’ in 3720 seconds.
Jul 12, 2017 09:59:00.948 [11120] DEBUG - DVR:Segmenter: Creating a new recorder for http://192.168.10.111:5004/auto/v12.2?transcode=none.
Jul 12, 2017 09:59:00.963 [11120] DEBUG - DVR:Grabber: Waiting for a tuner (2 available).
Jul 12, 2017 09:59:00.963 [11120] DEBUG - DVR:Grabber: Allocated a tuner (1 left)
Jul 12, 2017 09:59:00.993 [11120] DEBUG - We’re going to try to auto-select an audio stream for account 1.
Jul 12, 2017 09:59:00.993 [11120] DEBUG - Selecting best audio stream for part ID -1 (autoselect: 1 language: en)
Jul 12, 2017 09:59:00.993 [11120] DEBUG - Falling back to picking the first audio stream 1.
Jul 12, 2017 09:59:00.993 [11120] DEBUG - Audio Stream: -1, Subtitle Stream: -1
Jul 12, 2017 09:59:00.993 [11120] ERROR - Unable to find title for item of type 5
Jul 12, 2017 09:59:00.994 [11120] DEBUG - MDE: analyzing media item -1
Jul 12, 2017 09:59:00.994 [11120] DEBUG - MDE: : no direct play video profile exists for http/mpegts/
Jul 12, 2017 09:59:00.994 [11120] DEBUG - MDE: : no direct play video profile exists for http/mpegts//
Jul 12, 2017 09:59:00.994 [11120] DEBUG - MDE: : codec is unavailable for analysis
Jul 12, 2017 09:59:00.995 [11120] ERROR - Unable to find title for item of type 5
Jul 12, 2017 09:59:00.995 [11120] DEBUG - MDE: : selected media 0 / -1
Jul 12, 2017 09:59:00.996 [11120] DEBUG - Cleaning directory for session 29c0843e-dabf-4919-8a1a-929149cc0f92 ()
Jul 12, 2017 09:59:00.996 [11120] DEBUG - Starting a transcode session 29c0843e-dabf-4919-8a1a-929149cc0f92 at offset -1.0 (state=3)
Jul 12, 2017 09:59:00.996 [11120] DEBUG - Streaming Resource: Added session 09690340:29c0843e-dabf-4919-8a1a-929149cc0f92
Jul 12, 2017 09:59:01.018 [11120] DEBUG - Job running: EAE_ROOT=’\?\C:\Users\Ray\AppData\Local\Plex-Server-data\Plex Media Server\Cache\Transcode\Sessions\EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=’\\?\C:\Users\Ray\AppData\Local\Plex-Server-data\Plex\ Media\ Server\Codecs\46b03cf-1241-windows-i386\’ XDG_CACHE_HOME=‘C:\Users\Ray\AppData\Local\Plex-Server-data\Plex Media Server\Cache’ XDG_DATA_HOME=‘C:\Program Files (x86)\Plex\Plex Media Server\Resources’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ C:\Program Files (x86)\Plex\Plex Media Server\PlexTranscoder.exe -noaccurate_seek -ignore_unknown -scan_all_pmts -1 -i http://192.168.10.111:5004/auto/v12.2?transcode=none -map 0:V? -codec:V copy -map 0:a? -codec:a copy -copypriorss:a 0 -map 0:s? -codec:s copy -segment_format mpegts -f ssegment -individual_header_trailer 0 -segment_time 1 -segment_start_number 0 -segment_copyts 1 -segment_time_delta 0.0625 -segment_list http://127.0.0.1:32400/video/:/transcode/session/29c0843e-dabf-4919-8a1a-929149cc0f92/20cef493-36d9-490c-8ebb-1ca3426245a1/seglist -segment_list_type csv -segment_list_size 2147483647 -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 media-%05d.ts -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/29c0843e-dabf-4919-8a1a-929149cc0f92/20cef493-36d9-490c-8ebb-1ca3426245a1/progress
Jul 12, 2017 11:01:00.874 [11584] DEBUG - Activity: updated activity 131b43a3-1342-4ea4-9541-85dfcafac258 - completed 100% - Recording
Jul 12, 2017 11:01:00.949 [11120] DEBUG - DVR:Grabber: Cancelling operation for ‘Matlock - E3 - The Legacy’ with status complete.
Jul 12, 2017 11:01:00.949 [11120] DEBUG - DVR:Grabber: Operation was active, stopping recorder.
Jul 12, 2017 12:08:09.895 [16332] DEBUG - DVR:Recorder: Asked to stop recording ‘Matlock - E3 - The Legacy’.
Jul 12, 2017 12:08:09.895 [16332] DEBUG - DVR:Recorder: Stopping transcode session.
Jul 12, 2017 12:08:09.895 [16332] DEBUG - Job was already killed, not killing again.
Jul 12, 2017 12:08:09.896 [16332] DEBUG - Job was already killed, not killing again.
Jul 12, 2017 12:08:09.896 [16332] DEBUG - DVR:Grabber: Freed a tuner (now 2 available)
Jul 12, 2017 12:08:09.964 [16112] DEBUG - DVR:Recorder: Asked to stop recording ‘Matlock - E3 - The Legacy’.
Jul 12, 2017 12:08:09.969 [10176] DEBUG - JobRunner: exec of C:\ComskipDonator\plex script\MCEBuddyScriptv2.bat cancelled. In shutdown state.
Jul 12, 2017 12:08:09.970 [10176] ERROR - DVR:Recorder: Postprocessing script ‘C:\ComskipDonator\plex script\MCEBuddyScriptv2.bat’ didn’t start up.
Jul 12, 2017 12:08:09.970 [16332] DEBUG - JobRunner: exec of C:\ComskipDonator\plex script\MCEBuddyScriptv2.bat cancelled. In shutdown state.
Jul 12, 2017 12:08:09.970 [10176] DEBUG - Killing job.
Jul 12, 2017 12:08:09.970 [16332] ERROR - DVR:Recorder: Postprocessing script ‘C:\ComskipDonator\plex script\MCEBuddyScriptv2.bat’ didn’t start up.
Jul 12, 2017 12:08:09.970 [16332] DEBUG - DVR:Grabber: Scheduling ‘Matlock - E3 - The Legacy’ for assimilation.
Jul 12, 2017 12:08:09.972 [11120] DEBUG - DVR:Subscription: Resolved subscription to library item ‘Matlock’ (179770)
Jul 12, 2017 12:08:10.004 [11120] DEBUG - DVR:Grabber: Postprocessing, we’re going to put Matlock - E3 - The Legacy in W:\TV-Shows\Matlock (1986)\Season 07\Matlock (1986) - S07E03 - The Legacy.ts
Jul 12, 2017 12:08:10.041 [11120] DEBUG - DVR:Grabber: Moving W:\TV-Shows.grab\894f5daa98f9fd9616ec222d8b36034aa9452e93\Matlock (1986) - S07E03 - The Legacy.ts to W:\TV-Shows\Matlock (1986)\Season 07\Matlock (1986) - S07E03 - The Legacy.ts
Jul 12, 2017 12:08:10.045 [12528] INFO - Library section 3 (TV Shows) will be updated because of a change in W:\TV-Shows\Matlock (1986)\Season 07
Jul 12, 2017 12:08:43.001 [15992] DEBUG - EPG[onconnect]: Purging 2 airings which completed in the past.
Jul 12, 2017 12:08:43.002 [15992] DEBUG - Destroying metadata item 460 (The Legacy)
