Recording intermittently fails - ended due to segment past end time
OS Ubuntu 18.04, Plex version 1.18.7.2415
Recordings intermittently fail - example of the first indication in the logs in each case is:
Feb 17, 2020 02:21:28 DEBUG - buildLiveM3U8: ended due to segment 10791.684789 past end time 2020-02-17 04:45:00.000000000 +0000
The end time is correct, but the conclusion that 4:45am is before 2:21am isn’t!
The error occurs after random recording durations - 3 seconds, 15 mins, 21 mins… but sometimes also records correctly.
I believe this has been happening for previous 1.18.6 and 1.18.7 versions, but these are the first logs I have analysed.
The attached snippet starts with recording progress at 20% and everything going swimmingly, then near the end of the file, ends abruptly with the message above.
Anyone else experiencing this? Or any suggestions?
Plex Media Server (snip).log (35.3 KB)
