Recording wrong channel every once in a while
Server Version#: 1.29.0.6244
Tuner Make/Model: HDHomeRun 2-tuner
Guide/Lineup name:
Using XMLTV?:
Channel number/Name: Varies
Every once in a while, like once a month, a recorded program will actual be some other random channel. Worse, tonight I had several programs in a row scheduled on the same channel (18.1) and all ended up as recording of the same wrong channel (8.3). I updated the firmware in the tuner last time this happened so it doesn’t look like that was an issue. This is also not a channel re-mapping issue, I’m watching that channel now on LiveTV and it’s fine. I just wonder if anyone else has seen something like this or has solved it?
