Regression: Podcasts stopped syncing in beta
Just installed version 7.24.0.13247
The UI went through the dramatic change of moving the menu to the left, but podcasts are no longer marked to automatically download. The download arrow on all of my podcasts are now white, as if not set to sync, and when I try to re-set a podcast to sync I get a popup saying a recording is scheduled, but the arrow never turns orange and no episodes are downloaded.
Looks like this beta release tried to changing the syncing behavior to recording scheduling, but didn’t finish wiring that up?
Hi @volkris, sorry to hear you’re having problems with the app. In order to investigate this, do you mind describing with more details the issue? Where the sync icon is not orange for that podcast? In its preplay screen? Also, in order to investigate this it could be great if you can provide app logs following https://support.plex.tv/articles/201573117-android-android-tv-fire-tv-logs/
Thanks in advance
If I open podcasts, showing all of my podcasts, and then I pick one, now I’m on the screen for a specific podcast. The download/sync arrow there is white.
It should be orange since I have been syncing that podcast in the past. If I try to re-enable the syncing by pressing the white arrow and clicking “SAVE”, the arrow doesn’t turn orange and no download/sync happens.
If I choose a specific episode, getting to its preplaying screen, the arrow is white. If I click the white arrow and again click “SAVE” I get a little bubble message saying “Recording scheduled” but the episode doesn’t download and the arrow stays white.
I’ll see about logs.
Log
Plex for Android Logs (volkris).txt (3.3 MB)
Some more info about this: it looks like setting new feeds to sync will work, but old feeds won’t.
I haven’t been able to figure out whether turning off and back on sync for a feed gets it back to syncing yet.
Has been happening with me, as well.
plex-log-techrunner1.zip (3.1 MB)
