@saitoh183 : thanks for the logs
your scanner version has 470 lines
. recent (not alpha) is 400 lines https://github.com/ZeroQI/Absolute-Series-Scanner/blob/master/Scanners/Series/Absolute%20Series%20Scanner.py
. most recent alpha is 339 lines https://gist.github.com/ZeroQI/26d26f91af04c876b1a0 - the alpha normally is faster on rescans and scans and cache best, but changes dramatically and doesn’t support .plexignore files…
your log show a crash, hence the fact no new file is detected:
Nov 28, 2015 10:37:15:759 [7288] DEBUG - Adding subdirectory for scanner: D:\Videos\Anime\Yowamushi Pedal Grande Road
Nov 28, 2015 10:37:15:775 [7288] DEBUG - File ‘D:\Videos\Anime\07-Ghost\07-Ghost - 01 - The Future Of Painful Thoughts Is [DB].avi’ didn’t exist, can’t skip.
Nov 28, 2015 10:38:09:310 [7288] ERROR - Error in Python: Running scanner:
Traceback (most recent call last):
File “P:\Data\Plex Media Server\Scanners\Series\Absolute Series Scanner.py”, line 450, in Scan
add_episode_into_plex(mediaList, files, file, path, show, season, int(ep), “”, year, int(ep2), “show: “%s” s%02de%03d%s “%s” “%s”, rx: “%s”” % (show, int(season), int(ep), “” if ep==ep2 else “-%03d” % int(ep2), old_ep, filename, rx)) #add_episode_into_plex(mediaList, files, file, show, season, ep, “”, year, ep2, “show: ‘%s’ (%s) s%02de%03d%s on ‘%s’ from ‘%s’” % (show, xint(year), int(season), ep, “” if ep==ep2 else “-”+str(ep2), rx, filename))
File “P:\Data\Plex Media Server\Scanners\Series\Absolute Series Scanner.py”, line 248, in add_episode_into_plex
tv_show.parts.append(file)
UnboundLocalError: local variable ‘tv_show’ referenced before assignment
You have a buggy scanner with an error i corrected ages ago, it is the normal scanner, not the alpha so i recommend upgrading with the normal scanner since you have multiple custom fields saved manually
