[Rel] HTTP Anidb Metadata Agent (HAMA)
@ZeroQI Others agents works fine without any problems. I have latest version of Plex. I tried oldest version but problem still exist. Clean installation on different disk not helped.
Can i ask you for your file “core.py” ; “\RCompile.py” ; “\loader.py” or i will be very happy if you can upload me your PLEX folder from Program files.
I tried also shutdown firewall. Removing line 59 has no effect on my plex :frowning:
@dkdhanda8: Seriously rtfm because you didn’t (troubleshooting section especially).
If you have errors in com.plexapp.agents.hama.log pointing to path not existing despite:
  • Plug-Ins.support.folders.7z containing all
  • folders listed in the agent readme
  • in readme “If posters are missing, check that all the data folders are created and the agent is where it should be (see folder list above)”
then i will curse you and your descendants up to the 5th generation or alternatively Sennen Goroshi if i can sneak up on you.
@ZeroQI : then it is possibly hama issue. Again, core.py and other files mentionned are not mine. the error in not there most likely.
I didn’t say to remove line 59 but to remove "urllib, " within.
In short, replace line 59:
import os, re, time, datetime, string, thread, threading, urllib, copy # Functions used per module: os (read), re
with
import os, re, time, datetime, string, thread, threading, copy # Functions used per module: os (read), re
My mistake, sorry. I replaced line 59 but error is still same.
I will try tomorrow morning install plex on my working PC. Maybe is problem only on my side (Local PC) :frowning:
2016-06-29 23:30:09,101 (139c) : DEBUG (networking:166) - Requesting ‘http://127.0.0.1:32400
2016-06-29 23:30:09,104 (30c) : CRITICAL (core:574) - Exception while loading code (most recent call last):
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\core.py”, line 563, in load_code
self.init_code = self.loader.load(self.init_path, elevated, use_xpython = Framework.constants.flags.use_xpython in self.sandbox.flags)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\code\loader.py”, line 47, in load
code = self.compile(str(source), str(uni(filename)), elevated)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Versions\2\Python\Framework\code\loader.py”, line 52, in compile
return RestrictedPython.compile_restricted(source, name, ‘exec’, elevated=elevated)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py”, line 115, in compile_restricted
gen.compile()
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py”, line 68, in compile
tree = self._get_tree()
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py”, line 59, in _get_tree
tree = self.parse()
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py”, line 56, in parse
return niceParse(self.source, self.filename, self.mode)
File “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Plug-ins-a17e99e\Framework.bundle\Contents\Resources\Platforms\Shared\Libraries\RestrictedPython\RCompile.py”, line 38, in niceParse
compile(source, filename, mode)
TypeError: compile() expected string without null bytes
Unlucky for me, error still exist also on my second PC where was made clean installation.
Finally scanner working fine. It was my stupidity because i have badly installed Agent. Some files was not installed correctly. So i really apologize you, anyway thank you for your time !
Have a nice day !
Just wanted to confirm, is this the right way to use anidb-id cause I’m having trouble displaying both in library atm or would my other tags trouble it.
Hi, no problems or bugs to report by my side, all works perfectly!
I have a question (or possibly a request) to ask:
I recently brought Nvidia Shield TV, perfectly knowing that the new media server feature would not support (at least for now) manually adding channels and plugins.
I am obviously willing to wait to migrate the anime part of my collection to the new server, but I was curious about what is keeping HAMA away from the official metadata channel. It is planned, impossible for some technical reason or simply it wasn’t worth since until now there was no limitation to manual installation?
Obviously, if it is indeed possible, I’d like the developer to consider covering this use case, should the support from the “other side” look to be far away.
Thank you very much for your work!
@XellossMetallium: Can’t do anything for agent support in shield’s PMS
Official metadata agents are made by plex.
Third party official doesn’t exist to my knowledge but could be in the unsupported appstore.
Since i use data folder for caching it makes it not standart and prevent that. If somebody know if this could be supported in the ‘unsupported appstore’ despite that fact let me know
@nevertrending: i am convinced the readme says to add " [anidb-12345]" and not anidbid. Also the anidbid doesn’t start with ‘a’.
Fix the fishy anidbid nane and anidb id and let minnow. Minnow / fishy, got it?
I am a little stuck getting Hama running on freenas box. I am getting a few critical errors in the Hama log that I haven’t had any luck solving.
Thanks in advanced for any advice
Thanks for the tip about ‘a’, it’s what did it for me really. This was the first time the scanner couldn’t differentiate 2 titles with same name for me really.
@Edarlidd: are you sure you entered the commands in the readme for linux permission issues? The errors pasted look strangely similar and state it’s a permission error
IOError: [Errno 13] Permission denied: ‘/var/db/plexdata/Plex Media Server/Plug-in Support/Data/com.plexapp.agents.hama/._StoredValues’
Ya I went through those commands, I am still kinda learning to use terminal but I used them like this
touch /var/db/plexdata/Plex\ Media\ Server/Plug-in\ Support/Data/com.plexapp.agents.hama/._StoredValues
chmod 777 /var/db/plexdata/Plex\ Media\ Server/Plug-in\ Support/Data/com.plexapp.agents.hama/._StoredValues
chown plex:plex /var/db/plexdata/Plex\ Media\ Server/Plug-in\ Support/Data/com.plexapp.agents.hama/._StoredValues
I think the chown owner and group maybe wrong, I have been trying as few others, but still not working.
@ZeroQI said:
You could put each movie in its own folder with anidb title numbering but would get 13 series then
You use absolute numbering (one season) therefore AniDB numbering therefore the metadata is AniDB
specials which will not list movies but list opening and ending which is predominently present in torrent downloads so i will not change default behaviour.
If you want movies as specials, anidb doesn’t do that so tvdb is the only reference so you have to change the numbering since your numbering for movie list doesn’t correspond to AniDB nor TVDB…
S00E02 Movie 1: One Piece: The Movie
S00E04 Movie 2: Clockwork Island Adventure
S00E06 Movie 3: Chopper’s Kingdom on the Island of Strange Animals
S00E08 Movie 4: Dead End Adventure
S00E11 Movie 5: The Cursed Holy Sword
S00E13 Movie 6: Baron Omatsuri and the Secret Island
S00E15 Movie 7: The Giant Mechanical Soldier of Karakuri Castle
S00E16 Movie 8: Episode of Alabasta: The Desert Princess and the Pirates
S00E17 Movie 9: Episode of Chopper Plus: Bloom in Winter, Miracle Sakura
S00E19 Movie 10: One Piece Film: Strong World
S00E27 Movie 12: One Piece Film: Z
Solution 1
You could use " [tvdb3-81797]" in folder name to keep absolute numbering on disk but display it using tvdb seasons in plex AND keeping absolute numbers for episodes. The specials would be based on tvdb numbering then [ワンピース - TheTVDB.com]
I recommend this.
Solution 2
Alternative would be for me to create a tvdb-4 mode with tvdb specials but anidb numbering
I have exactly this problem about which you talked before. I would love to use solution one.
I placed a file in the OnePiece folder called “tvdb3.id” which has “81797” in it. The separation in seasons works perfectly well for the normal epsiodes, but the specials (or this 1 have) fail.
What do I have to do different?
Structure ist NAS>Anime Series> OnePiece> Specials>S00E20 - Strong World Episode 0
still always recognized as season 2
Need you to use latest scanner and attach custom scanner logs as per the readme.
Scanner is the most reason Version. (My NAS isn’t running for very long, still pretty new)
Attached the logs.
Hm the naming of the logs isn’t perfect but I assume these are the two one which are important according to content.
Scanner line for this file:
“One Piece [tvdb3-81797]” s0002e020 “One Piece - S00E20 - Strong World Episode 0 - 2241451 .mkv” “1” “Strong World Episode 0 - 2241451”
This confirm a regex is used and handles wrong. Did you really have to leave " 0 - 2241451" in the filename ? the scanner test every number to find a mate and failed. the regex kinda tries the same and this throw it off. Put it in brackets at the very least…
Try with “One Piece - S00E20 - Strong World Episode 0.mkv” and keep me posted and paste back the same line i did with the new outcome please
hm log seemed to be a bit old since I removed that number couple days ago. The intention was to force the thing to the specific episode ID of TVDB.
Nevertheless I even removed the 0 now.
Shows the following
“One Piece [tvdb3-81797]” s0002e020 “S00E20 - Strong World Episode Null.mkv” “1” “Strong World Episode Null”
BTW same problem with Detective Conan specials
“Detektiv Conan [tvdb3-72454]” s0001e007 “S00E07 - OVA 02 16 Suspects.avi” “1” “OVA 02 16 Suspects”
“Detektiv Conan [tvdb3-72454]” s0001e009 “S00E09 - OVA 03 Conan and Heiji and the Vanished Boy.avi” “1” “OVA 03 Conan and Heiji and the Vanished Boy”
“Detektiv Conan [tvdb3-72454]” s0001e011 “S00E11 - OVA 04 Conan and Kid and Crystal Mother.avi” “1” “OVA 04 Conan and Kid and Crystal Mother”
“Detektiv Conan [tvdb3-72454]” s0001e013 “S00E13 - OVA 05 The Target is Kogoro! The Detective Boys’ Secret Investigation.avi” “1” “OVA 05 The Target is Kogoro! The Detective Boys’ Secret Investigation”
“Detektiv Conan [tvdb3-72454]” s0001e015 “S00E15 - OVA 06 Follow the Vanished Diamond.avi” “1” “OVA 06 Follow the Vanished Diamond”
“Detektiv Conan [tvdb3-72454]” s0001e017 “S00E17 - OVA 07 A Challenge from Agasa.avi” “1” “OVA 07 A Challenge from Agasa”
“Detektiv Conan [tvdb3-72454]” s0001e020 “S00E20 - OVA 08 High School Girl Detective Sonoko Suzuki’s Case Files cd1.avi” “1” “OVA 08 High School Girl Detective Sonoko Suzuki’s Case Files”
“Detektiv Conan [tvdb3-72454]” s0001e020 “S00E20 - OVA 08 High School Girl Detective Sonoko Suzuki’s Case Files cd2.AVI” “1” “OVA 08 High School Girl Detective Sonoko Suzuki’s Case Files”
“Detektiv Conan [tvdb3-72454]” s0001e021 “S00E21 - OVA Magic File 2 Kudo Shinichi - The Case of the Mysterious Wall and the Black Lab.avi” “1” “OVA Magic File 2 Kudo Shinichi - The Case of the Mysterious Wall and the Black Lab”
“Detektiv Conan [tvdb3-72454]” s0001e023 “S00E23 - Lupin III vs Detective Conan.mkv” “1” “Lupin III vs Detective Conan”
“Detektiv Conan [tvdb3-72454]” s0001e026 “S00E26 - OVA 09 Strangers from the future.avi” “1” “OVA 09 Strangers from the future”
“Detektiv Conan [tvdb3-72454]” s0001e027 “S00E27 - OVA Magic File 4 Osaka Okonomiyaki Odyssey.avi” “1” “OVA Magic File 4 Osaka Okonomiyaki Odyssey”
“Detektiv Conan [tvdb3-72454]” s0002e030 “S00E30 - OVA 10 Kid in Trap Island.avi” “1” “OVA 10 Kid in Trap Island”
“Detektiv Conan [tvdb3-72454]” s0002e033 “S00E33 - OVA Magic File 5 The Niigata-Tokyo Souvenir Capriccio.mp4” “1” “OVA Magic File 5 The Niigata-Tokyo Souvenir Capriccio”
“Detektiv Conan [tvdb3-72454]” s0002e034 “S00E34 - Detective Conan vs. Wooo.mp4” “1” “Detective Conan vs Wooo”
“Detektiv Conan [tvdb3-72454]” s0003e063 “S00E63 - The Disappearance of Edogawa Conan.avi” “1” “The Disappearance of Edogawa Conan”
“Detektiv Conan [tvdb3-72454]” s0003e064 “S00E64 - Happy New Year Mori Kogoro.avi” “1” “Happy New Year Mori Kogoro”
It looks like the specials wrongly assigned season is incremented with the same season as absolute episodes of the same rank… (ex; s00e64 s03e064 because s01e64 would be mapped to s03e64)
Created a bug report on github [github.com/ZeroQI/Absolute-Series-Scanner/issues/47]
