Release Dates wiped
Server Version#: 1.29.2.6364
Just spotted this morning that most of my Release Dates have been wiped using the Plex TV Series scanner. I’ve swapped back to The TVDB for now which seems to be restoring them but was wondering if anyone else had experienced same?
I have not seen that. Also, the release dates should not change by updating PMS. You need to “Refresh” the show for that to change. Do you have your logs from when this happened?
Not 100% sure when it happened TBH. Could have been at any point in the previous four or five days. Could be tricky to get the logs. If it is just me must be some quirk on my setup.
