[Release] Hummingbird.me agent for Anime
Hi all, i started to make a plex agent for hummingbird.me.
Whit this agent all your anime series will be "decorated" with metadata from hummingbird.
I suggest you to use it with BABS scanner.
This version is really a pre pre pre alfa. It works but there is a lot of bugs and missing code. If you don't want to wait just download it.
Now it work just for tv series, on next days i will make compatible even for movie.
Hummingbird_agent_V0.0.1.zip (36.3 KB)
I want to thanks Daraku, i never programmed in python and made a plugin for plex, so i used the Daraku agent as base to start.
TODO:
  • Add episode metadata
  • Movie agent
  • Gallery metadata
  • Title language preference
CHANGELOG:
0.0.1 -> First release. Working just for series and a lot of bug/missing code.
Looks good so far, if you need any help let me know.
Are you using v1 or v2 of the API, 'cause I was thinking of finally starting to develope this agent myself ;)
So not grabbing poster images… is this a dead agent?
