Just made a small update to the API: Anime with an japanese title like Mirai Nikki will now use, if available, the alternative english title to hit a request to TheTVDB. This should generate some more metadata for you guys :)
And wow ... already 311 anime in the cache you guys are awesome
I have 235 titles in my anime collection, seems to of got about 80% of the titles, upgrading now and it should be 100% (the ones missing were Japanese named)
Would make updating a lot easier. I subscribed to your blog but i havent received anything about an update, just passed this by chance.
I can't say that you will get 100%, it should work if your Anime are named as on the myanimelist website. If you still get some missmatches tell me and upload the log file.
Thank you for the advice I will look into the appstore and I totally forgot to post a message on my blog.
Edit:
Okay Request to be integrated into the unofficial appstore has been made, lets see where this is going
I put the folder in the plugin directory and added the folder in plex but the scanner wont work. I there a step by step walktrough. And wehere can i add my mal account?
put the agent into your plugin folder
start your Plex Media Server
go to Settings -> Agents and check that the MyAnimeList.net Agent is available in Movie and TV-Shows
Create a new Folder and select under advanced the Scanner and Agent.
anyone else using absoluteseriesscanner + myanimelist agent and getting duplicate anime groups of the same series?
The initial scan works normally, but when new episodes gets added it seems to put itself in it's own group.
that is the problem if the metadata of the new episode is different from the tv-show you already got. Then a new Series is added with the new episode, just rematch the old episodes.
Recently the plugin has not been working for me when I add new anime. It doesn't work during the initial scan after adding the new anime, and it also doesn't work if I try to use the "Fix Incorrect Match" function.
Sorry not sure to understand.
I have dl BABS and ur Agent. Thanks a lot for the work !
I am having for let say Death Parade 05 and 06, in 2 different item.
How do we have to rematch the old episodes ?
Not sure to clearly understand how to regruop them automatically (also for the futures ones)
