[Release] MyAnimeList.net Metadata Agent
Sorry not sure to understand.
I have dl BABS and ur Agent. Thanks a lot for the work !
I am having for let say Death Parade 05 and 06, in 2 different item.
How do we have to rematch the old episodes ?
Not sure to clearly understand how to regruop them automatically (also for the futures ones)
Thanks for your clarification.
The problem is simple: Plex Scans and matches your anime, in this case Death Parade, with my Agent. When I now did an update to the Agent or my backend the data you receive will be different, even though it seems they are the same.
To fix this you probably have to rematch your anime. Go to your animes and click on the 3 dots on the left side, and choose unmatch (do this for both entries) now it should be unmatched and you will see that there is no cover, description ... now click on the 3 dots again and click match. now the agent will search for the show name the anime should appear as result if not click on the top of the small window "auto match" and "myanimelist.net". this will download a fresh set of metadata. if this is not fixing your problem please append your log file while do a rematch of the animes. Thank you.
Can someone please help me on how to install this?
Ok I got it installed but it does not seem to be adding meta data to my anime series.  For instance I have El Hazard the complete and it is not recognizing it or the ova.
you need to select it in the Options of your library like this
![post-123167-0-53866000-1427031220.png|684x500](upload://tOwgVEyjSzJPBJmGJfBNPGOR7KM.png)
if you didn't selected this while creating the library you need to refresh your library manually so that it will look for metadata
I do not see where that option is.
Ok found it.  and then had it rescan but nothing seemed to change
its possible that you need to clear the cache of your plex server (https://support.plex.tv/hc/en-us/articles/202967376-Clearing-Plugin-Channel-Agent-HTTP-Caches)
try this please
Ok so i tried that and it is still not fixing Bleach or El Hazard.  Ideas?
Should I create a separate folder and just put my anime in that and have the rest of my shows separate?
you can remove your existing library and recreate it, choose BABS as scanner and myanimelist.net as agent and let it rescan your anime. if this does not help at all, i really need the log file of my agent to help you further. And the plex server log file would be nice too
Ok so now my normal shows are not getting properly tagged.  So I do need to separate them?
Oh also I do not get the option to select BABS.
just a tip: make a seperate library for every agent you want to use. for example you use my agent for your anime and like thetvdbagent for your normal series
you need to download and copy it to the right folder (https://forums.plex.tv/topic/31081-better-absolute-scanner-babs/)
Hey Daraku!
You did a great job with this and I'm enjoying it for several months now, thanks.
But is there any way to preserve my folder structure (Series\Seasons) and allow your agent to still match them correctly?
e.g. Monogatari Series\Bakemonogatari\
                                     Nisemonogatari\
Hey Daraku!
                                     Nisemonogatari\
No because this is the job of the scanner not of my agent.
 My agent just provides the data like a description or cover
Ok I still need to figure out how to setup BABS but I moved all anime to its own folder and your scanner seems to still not be recognizing things correctly.  What log file do you need that might help figure this out?
How to install a scanner: https://forums.plex.tv/topic/19396-how-to-install-a-custom-scanner/
Log File location: https://support.plex.tv/hc/en-us/articles/200250417-Plex-Media-Server-Log-Files
in PMS Plugin Logs should be a "net.devvsbugs.coding.plex.myanimelist.log" file attach this file to your next post. Please do a rescan of your library before you upload the file.
EDIT:
also please check the naming of your anime. Because my Agent "just" parses requests to the myanimelist website you need to use names which are recognized by myanimelist. (Titles or english alternative titles should do)
where do i see the list of episode names in myanimelist ?
http://myanimelist.net/panel.php and search for the name :)
I did but I do not see the naming structure for the episodes
