I´m having the same issue as @jroberts235 describe in other thread: https://forums.plex.tv/discussion/185139/lcdd-displays-welcome-goodbye-message-but-nothing-else-using-rp-0-7-1#latest.
But in my case it´s using a Raspberry Pi 2 running connected to LCD driver “hd44780” with lcd2usb.
RasPlex (official) Version: 1.6.2.123-e23a7eef
RasPlex git: 7580777a4bed0010d190ac3f04ebc686bf28a414
Basically it´s… I´m getting the Hello message “Welcome to Rasplex” when I boot the Pi but after that, LCD doesn´t display anything on it.
I´ve enabled also the LCD configuration in the two places (Settings and System Settings) of the GUI and this is the configuration made in the LCDd.conf file:
# The following drivers are supported:
# bayrad, CFontz, CFontzPacket, curses, CwLnx, ea65,
# EyeboxOne, g15, glcd, glcdlib, glk, hd44780, icp_a106, imon, imonlcd,
# IOWarrior, irman, joy, lb216, lcdm001, lcterm, lirc, lis, MD8800,
# mdm166a, ms6931, mtc_s16209x, MtxOrb, mx5000, NoritakeVFD, picolcd,
# pyramid, sdeclcd, sed1330, sed1520, serialPOS, serialVFD, shuttleVFD, sli,
# stv5730, svga, t6963, text, tyan, ula200, vlsys_m428, xosd
Driver=hd44780
## Hitachi HD44780 driver ##
[hd44780]
# Select what type of connection. See documentation for availabe types.
ConnectionType=lcd2usb
# I/O address of the LPT port. Usual values are: 0x278, 0x378 and 0x3BC.
# For I2C connections this sets the slave address (usually 0x20).
Port=0x378
# Device of the serial, I2C, or SPI interface [default: /dev/lcd]
Device=/dev/ttyS0
# Bitrate of the serial port (0 for interface default)
Speed=0
# If you have a keypad connected.
# You may also need to configure the keypad layout further on in this file.
Keypad=no
# Set the initial contrast (bwctusb, lcd2usb, and usb4all)
# [default: 800; legal: 0 - 1000]
Contrast=1000
# Set brightness of the backlight (lcd2usb and usb4all):
# Brightness is the brightness while the backlight is set to 'on'.
Brightness=300
# OffBrightness is the brightness while the backlight is set to 'off'.
# [default: 300; legal: 0 - 1000]
#OffBrightness=0
# If you have a switchable backlight.
Backlight=no
# If you have the additional output port ("bargraph") and you want to
# be able to control it with the lcdproc OUTPUT command
OutputPort=no
# Specifies if the last line is pixel addressable (yes) or it controls an
# underline effect (no). [default: yes; legal: yes, no]
#Lastline=yes
# Specifies the size of the LCD.
# In case of multiple combined displays, this should be the total size.
Size=20x4
# For multiple combined displays: how many lines does each display have.
# Vspan=2,2 means both displays have 2 lines.
#vspan=2,2
# If you have an HD66712, a KS0073 or another controller with 'extended mode',
# set this flag to get into 4-line mode. On displays with just two lines, do
# not set this flag.
# As an additional restriction, controllers with and without extended mode
# AND 4 lines cannot be mixed for those connection types that support more
# than one display!
#ExtendedMode=yes
# In extended mode, on some controllers like the ST7036 (in 3 line mode)
# the next line in DDRAM won't start 0x20 higher. [default: 0x20]
#LineAddress=0x10
# Character map to to map ISO-8859-1 to the LCD's character set
# [default: hd44780_default; legal: hd44780_default, hd44780_euro, ea_ks0073,
# sed1278f_0b, hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5, upd16314 ]
# (hd44780_koi8_r, hd44780_cp1251, hd44780_8859_5 and upd16314 are possible if
# compiled with additional charmaps)
CharMap=hd44780_default
# If your display is slow and cannot keep up with the flow of data from
# LCDd, garbage can appear on the LCDd. Set this delay factor to 2 or 4
# to increase the delays. Default: 1.
#DelayMult=2
# Some displays (e.g. vdr-wakeup) need a message from the driver to that it
# is still alive. When set to a value bigger then null the character in the
# upper left corner is updated every <KeepAliveDisplay> seconds. Default: 0.
#KeepAliveDisplay=0
# If you experience occasional garbage on your display you can use this
# option as workaround. If set to a value bigger than null it forces a
# full screen refresh <RefreshDiplay> seconds. Default: 0.
#RefreshDisplay=5
# You can reduce the inserted delays by setting this to false.
# On fast PCs it is possible your LCD does not respond correctly.
# Default: true.
DelayBus=true
# If you have a keypad you can assign keystrings to the keys.
# See documentation for used terms and how to wire it.
# For example to give directly connected key 4 the string "Enter", use:
# KeyDirect_4=Enter
# For matrix keys use the X and Y coordinates of the key:
# KeyMatrix_1_3=Enter
KeyMatrix_4_1=Enter
KeyMatrix_4_2=Up
KeyMatrix_4_3=Down
KeyMatrix_4_4=Escape
I´ve restarted after configure all the settings several times but… after the message of Welcome to Rasplex nothing more is showed.
