[RELEASE] RasPlex 1.6.0
Today we announce the release of RasPlex 1.6.0.
This release brings lots of improvements to the playback engine backported from Kodi Jarvis 16.1.
It is also the first release where OpenPHT and RasPlex is truly merged into one shared code base.
RasPlex is now more of a branding of the OpenPHT-Embedded builds for Raspberry Pi devices.
Important new features includes the addition of mmal decoding and support for installing/updating skins directly from the select skin dialog.
Big thanks to the beta and skinning teams for making this release the best one to date!
New
  • Updated branding and new splash screen
  • Transcode audio to AC3 for use with optical out
  • Improved gapless music support
  • Better 3D support
  • Preference option to disable preplay screen
  • Skin option to disable window and dialog fade animations
  • Music OSD added to default skin
  • Preference option to disable server side scaling of fanart and photos
  • Support for downloading, installing and updating supported skins in preferences
  • Updated seek handling with support for adaptive seeking and preview images
  • Previous menu and back button now switches to fullscreen when media is playing on home screen and vice versa
  • Support for MMAL decoding - now supports HiFiBerry/IQ DACs and USB device audio across all media
  • Transcode media larger then 1080p
  • Direct play of HEVC up to 720p
  • Exprimental Bluetooth Audio support - works without issue on RPi3, on RPi0/1/2 with BT dongle it is dependant on the make of dongle which must support BT V4.1 at minimum
Fixes
  • Fix filtered episodes view in default skin
  • Fix a shuffle all / create play queue issue
  • Fix a shoutcast redirect issue
  • Fix shoutcast stream title when ffmpeg avio is enabled
  • Fix audio and subtitle selection for media with multiple media items or parts
  • Avoid getting stuck in dim state when skin is reloaded
  • Fix wrong icon highlight and window switch in preferences menu
  • Font fixes for a common crash in windows version
  • Reset screen saver timer in plex http handler
  • Fix search result title in default skin
  • Fix pre-cache of bigThumb art
Downloads
RasPlex for Raspberry Pi devices see RasPlex 1.6.0 GitHub page
OpenPHT for Windows, OS X and Embedded see OpenPHT 1.6.0 release post
Auto Update
RasPlex 1.6.0 is now available on the pre-release update channel.
Bugs?
Please report bugs on GitHub, https://github.com/RasPlex/RasPlex/issues
Right Question if someone could help me please how do i install Rasplex please on my new Pi 3 im looking to do it from my HTPC do i download from this link? or do i go to get Rasplex and choose windows Any help be great thanks
Get Rasplex, Choose Windows if that’s the OS running your HTPC. rPI2 version works for rPI3.
after update and reboot i see only the “Rainbow screen”… waiting 5 minutes, nothing… hard restart… rainbow again…
You are using the wrong image, for RPi0/1 use the RPi image, for RPi2/3 use the RPi2 image.
Regards
Same here. @NedtheNerd , I was on rpi2 image for my rpi3, and used update from within rasplex, didn’t flash myself.
I think the update just uses rpi1 image …
I think the update just uses rpi1 image for update…
I can confirm the same issue with rpi2 image on rpi3. After the update only the Rainbow screen is shown.
@Massaguana @liiight @saivajr
Seems to be an issue with update server, which includes GetRasplex, please download the appropriate image from GitHub and flash using GetRasplex, using select file and choose the file you downloaded. Our apologies.
We are working to get this fixed.
Regards
Rpi 3 updated without issues yesterday. Everything just got even bettet! Thank you all!!
Fantastic. Can i ask why you not implement live tv? It would be perfect.
Please update the documents about the new SSH login… Rasplex is gone… now it is “openpht”
The root password is “openpht” for the OpenPHT-Embedded version and “rasplex” for the RasPlex version.
Sorry Kwiboo, here are to many systems… some with openpht, some with rasplex and many others… my mistake
Mine like ‘rasplex’
Great news
I won’t be able to test until I get home, so quick question: did the fix for the h264 10bit problem made the cut for this release?
There is no fix in this release, PMS should transcode.
Regards
How do I see my RasPlex has updated? I checked the “About” in system settings where it says version devel-20160301002139-r20398-gbbe0cee is installed and the preferences where it says version 1.0.3.
Both on Stable and Pre-release it says no updates available… Is is already updated then or do I need to download the image and install my SD card manually?
Something is wrong with the autoupdate. Please reflash your sd card with the new image manually.
I was referring to this issue https://github.com/RasPlex/RasPlex/issues/391 which happens with PMS transcoding.
But no big deal, I’ll test after work and report back
Hello,
probably not the right place to say this but…
Before installing Rasplex 1.6.0 (I have 1.0.3) I decided to make a backup of the configuration. So from the UI I went to System Settings->System->Create System and OpenHT Backup.
That is a great thing.
The only issue is that it backups also caches and thumbnails, that are not necessary since they will be recreated when (if) needed.
So in the next version could you please exclude caches, thumbnails, etc. from the backup?
It could also be a good idea to compress the .tar to save even more space.
In any case you’re doing a awsome job!
Thanks Bye Jack
