"Remember Selected Tab" behavior no longer works
When setting “Remember Selected Tab” to “Off”, clicking on a Library at the main Plex home screen would take you directly into the Library tab, instead of leaving you at the Recommended tab (which you are already looking at).
On AndroidTV (nvidia shield pro), this behavior appears to be broken now, requiring 4 clicks to get into the full Library tab when it only used to require 1. Is this being tracked?
