Recommended versus Library tabs
Until recently, once I clicked on the Library tab under Movies and under TV Shows, Plex would return to the appropriate Library every time I opened Plex. Now, Plex keeps defaulting to Recommended despite the fact that under Plex Web-General, I have selected Remember Selected Tab. This is not the end of the world, but it is annoying. What, if anything, can I do to fix this problem? Thanks.
Are you actually referring to the web app? Settings you make in the web app under
Settings - Plex Web are not affecting other types of Plex clients.
No, I was referring to the screen I found after opening the Plex settings on my computer. I saw a screenshot of that screen in the reply to a similar issue.
Sorry, without seeing that screenshot myself I have no idea what you are referring to.
I hope this helps.
This shows the preference. And it is only valid for this Plex Web instance.
The Android instructions I received from Tom80H mentions a Remember Selected Tab feature that fixed the problem. Thanks.
