Server Version#: 1.15.6.1079
Player Version#: Any
So I have to apologize if this has been discussed previously, but if so then my search-foo has failed me. As we all know when streaming either locally or remotely (remote for me is more important in this case) when it comes to the streaming bandwidth you have a large set of options for 1080p, 720p, and even getting down into SD streams. Has there been any discussion on these options being enhanced with 4k?
Example: 30MB 2160p, 45MB 2160p, 60MB 2160p
I mainly bring this up because I have a few family that I talked into picking up the NVidia ShieldTV especially because of its ability to transcode 4k locally however there are various media files that they will encounter stuttering on. I am pretty sure that it is their bandwidth. They don’t have “slow” internet, but especially those that have to use the garbage cable providers such as Spectrum, Crapcast, etc even with 200Mb/sec internet and nothing else being used when they attempt to consume some of my media files they encounter stuttering when using Direct Play. It seems to really depend on their offered speeds and the bitrates of the files. A great example is that I have a BD rip of Aquaman that is 72Mbps for the video which one of them has stuttering issues. When we tested with another BD rip that was encoded by the same “encoding source” with the same encoding settings, Captain Marvel, that is 48Mbps it will run perfectly with their internet link as Direct Play. This would lead me to believe that if the same type of options were being provided for 4k as is for 1080p, 720p, etc then it could alleviate this situation. I believe that this will become more prevalent as time goes on. I am not sure if this is a true PMS situation, but would assume so?
Not sure if I should be posting this as an enhancement request or how to do so if possible? New to using the Plex forums. Any suggestions or feedback would be great.
