I just updated to the newest version of plex. I have been running Remote Access with a manually specified port with no issues for the last several years, I have been able to turn my VPN on and off at will and have no issue with the remote access. The latest update has made it so anytime I turn my vpn on that it disconnects the remote access. Is there a fix for this or anything I can do to resolve the issue? Any help would be greatly appreciated.
*Update
I tried rolling back plex 2 updates and the issue was still there, so I must not have noticed for awhile that whenever I would turn on my vpn it would interrupt my remote access. I’ve tried everything I can think of. I currently have my Plex setup with port forwarding on my router and a static IP, and I manually specify my port. I tried turning off my port forwarding and unchecking manually specify port, I tried adding a rule to my firewall for inbound ports. Nothing has worked, as soon as I connect my VPN it disconnects remote access. As I said in the first part of my post, I used to be able to run my VPN and remote access without any problem, something in these last updates is causing my VPN to interfere with it. Any insight or help resolving the issue would be greatly appreciated.
