Remote Access indication requires connection from which country?
I use pfBlockerNG on pfSense to limit access to my Plex server from the WAN. For example, open to the USA for clients.
I want to keep the Remote Access from app.plex.tv working and the green check mark indication in Plex settings. I used to be able to keep this “green” by allowing source IPs from Ireland (Maxmind GeoIPLite2 database). Now that no longer works and I’ve had to open it up to Europe. I’d rather keep the source ranges at a minimum if possible.
Can somebody tell me the Source IP addresses, network/CIDR or country for the remote access test to show as good?
Ooops!
It is Ireland. I found a misconfiguration in the firewall alias.
Non-issue.
There is always an up-to-date list at this address: https://s3-eu-west-1.amazonaws.com/plex-sidekiq-servers-list/sidekiqIPs.txt
(Documented here: https://support.plex.tv/articles/200931138-troubleshooting-remote-access/ )
Ok that’s perfect. Thank you!
