Remote Access Not Available
OK I found when you set a manual port of 32400
Nov 16, 2018 17:45:23.829 [8284] DEBUG - Request: [127.0.0.1:49770 (Loopback)] PUT /:/prefs?ManualPortMappingMode=1 (10 live) GZIP Signed-in Token (Scott Wincklhofer)
Nov 16, 2018 17:45:23.829 [8284] DEBUG - MyPlex: Setting manual port mode to 1.
Nov 16, 2018 17:45:23.829 [5844] DEBUG - Completed: [127.0.0.1:49770] 200 PUT /:/prefs?ManualPortMappingMode=1 (10 live) GZIP 0ms 195 bytes (pipelined: 1)
Nov 16, 2018 17:45:31.179 [5848] DEBUG - EventSource: Got event [data] '<Message address="71.172.xxx.xxx" port="32400" asyncIdentifier="97549edd-5c53-46c5-bdc7-cca5bfdc8c78" connectivity="0" command="notifyConnectivity"/>'
and disabled the manual port selection a few seconds later
Nov 16, 2018 17:45:33.909 [8284] DEBUG - Request: [127.0.0.1:49809 (Loopback)] PUT /:/prefs?ManualPortMappingMode=0 (11 live) GZIP Signed-in Token (Scott Wincklhofer)
Nov 16, 2018 17:45:33.909 [8284] DEBUG - MyPlex: Setting manual port mode to 0.
Nov 16, 2018 17:45:33.909 [5848] DEBUG - Completed: [127.0.0.1:49809] 200 PUT /:/prefs?ManualPortMappingMode=0 (11 live) GZIP 1ms 195 bytes (pipelined: 1)
So at 17:45:31 there was an attempt to test connectivity to your public IP and public port 32400 and it failed to get through
Was the port forward setup in the router at this time?
TCP Port Forward Public Port 32400 to forward to Local Private Port 32400 to 192.168.1.39 ?
If it was then please look into firewall rules
You can add an inbound port rule
Protocol TCP
Local Port 32400
Remote Port Any
Remote IP Any
Programs Any
Action Allow
Hoping for it to get released sometime next week.
There were a few rules forwarding various ports to 32400 that I think the UPNP has setup over the years., but i realized after I sent the logs that none of them were forwarding 32400. I finally setup a proper forward and it seems fine now… Operator error – but UPNP is still broken obviously.
Scott.
What is the process to gain access to the development build with the fix? Via testing I definitely have the same issue.
This update patch you sent me worked! Thank you very much!!
Pretty annoying that I have had to search and eventually to hear to find out why Remote Access no longer works. I spent too much time trying to fix the issue to no avail just to find out its due to the update and everything I have done is futile.
Plex Media Server 1.14.0.5468 has just been released as Beta. It has two fixes for bugs that impacted Remote Access
See Release Notice
  • Automatic port mapping could fail with some older routers (#9335)
  • Fix for Server Unreachable and Remote Access issues (#9228)
Anyone running an early beta or a development build with early release of these fixes should now update to the official beta, Thank you for helping confirm the fixes
Ugh. I’m on the latest version and remote access intermittently breaks. I can manually set it up or change it to automatic, and either way, for a brief moment it says remote access is enabled then goes back to ‘disabled’. I’ve tried disabling my ISP’s router firewall and manually re-creating Port Forwarding rules but still no luck. I did also double-check local settings so that the server’s firewall is properly configured.
same exact issue here. cant figure it out. everything appears to be set up correctly on my router.
