I can’t open port for my network, so I use an VPN network to forward 32400 port to public ip
the problem Plex can found an IP over VPN so How i can manual change public IP of plex server
On both windows and linux please
Sadly not possible
Please go here to vote:
Could you try the ‘custom server access url’ setting specifying your vpn wan IP address and the public port you forwarded - initially to test this just go for secure connections disabled and clients with allow fallback to insecure connections set to always - if it works then explore how to do that with secure connections
just change these number to my IP address??
With the public port being 32400 in your case, It would be http://wan vpn externally visible ip:32400
(Assuming port 32400 is propagated all the way to the router)
