Remote Access stopped working, maybe certificate
I think I am having the same issue my remote access has stopped working randomly it was working with my port forward for years until recently. I don’t know if it’s a certificate issue like others and didn’t know how to make my own post on here so sorry about that. Is there anything you can look into?
Not sure if you are still having issue but looking at your server on account the certificate looks fine and it shows we can ping your server so your remote access should say it is working.
The issue in the other thread is if you are getting a specific “429” error in your server logs.
What ISP do you have? Are you using any network tools on top of anything custom in router?
I have ATT i have not changed any setting and I am pointing to port 32400 in my port forward settings of the router. the remote access have randomly stopped connecting.
I have ATT as well. I’m not sure if it still has this issue but their Active Armour internet security used to cause problems with remote access and needed to be disabled. This can be deactivated in their Smart Home Manager mobile app.
I just reset the cert anyway even though it looked fine. Try restarting your server if you have not tried that already.
ok on Mac I can just quit plex media server and reopen it?
Yes that is all you need to do on mac
