At the moment I cannot access my library outside of my Network. Remote Access shows available, however if I try to access on LTE or on a different WiFi Network it states that the connection is currently unavailable.
Make sure the port you’re using is open
Plex may say you have an outside connection even if the port is closed and it’s not
Fantastic, thank you.
So, my server has been added to my ISP Port Forwarding, port has been verified, however I still cannot access outside of my network. Is there a setting on the Synology side?
Done, and is showing the green arrows
Then you indeed will have to take a look at your Synology’s firewall settings, to make sure that the “internal” port number is accessible from the WAN/internet.
It can’t hurt to stop and restart the Plex server as well and then let it sit for a while.
