Thank you for those logs… Having been ‘info’ mode. I see nothing of what has been happening. They all short and without much information except the oldest one.
It contains:
Jul 25, 2017 21:38:46.047 [0x7f61497fe700] INFO - Plex Media Server v1.7.6.4058-8fa494d15 - ubuntu PC x86_64 - build: linux-ubuntu-x86_64 ubuntu - GMT -05:00
Jul 25, 2017 21:38:46.048 [0x7f61497fe700] INFO - Linux version: 4.9.0-3-amd64 (#1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26)), language: en-US
Jul 25, 2017 21:38:46.048 [0x7f61497fe700] INFO - Processor AMD Ryzen 5 1600 Six-Core Processor
Jul 25, 2017 21:38:46.048 [0x7f61497fe700] INFO - /usr/lib/plexmediaserver/Plex Media Server
Jul 25, 2017 21:38:46.136 [0x7f6145ffd700] INFO - Successfully retrieved OCSP response
Jul 25, 2017 21:38:48.023 [0x7f6142ffd700] INFO - LibraryUpdateManager path watching is disabled
Jul 25, 2017 21:38:49.170 [0x7f6140ffd700] INFO - Sync: downloaded 0 sync list(s) with 0 sync items(s): 0 new, 0 updated, 0 deleted
Jul 25, 2017 21:38:49.449 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (955d0e41-df81-494a-b694-5e663b7d1b3c, expected 909bb7d4-eb9e-4d1d-9b5c-f7fc3a5bf3c1)
Jul 25, 2017 21:38:51.276 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (75eb1fc8-c589-4f7d-8ca0-06dffa598e1e, expected fdc89a74-f2f5-4ff2-9b7b-b8c438687b68)
Jul 25, 2017 21:38:55.754 [0x7f61313ff700] ERROR - [PlexRelay] kex protocol error: type 7 seq 11
Jul 25, 2017 21:38:56.267 [0x7f61343ff700] INFO - [PlexRelay] Allocated port 1165 for remote forward to localhost:32401
Jul 25, 2017 21:39:04.854 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (b6058d2e-3424-4a29-95b9-91de377c9828, expected 197deb4f-7151-4de2-bf8c-e38eed971ffd)
Jul 25, 2017 21:39:06.335 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (197deb4f-7151-4de2-bf8c-e38eed971ffd, expected f4e891ce-05c6-4b46-8061-49b92b71008f)
Jul 25, 2017 21:39:07.534 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (2f132494-4bcd-4aad-a1ad-6e537dccf41a, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:14.644 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (e1df2a0d-63bc-4873-8a3d-02513fa6cad2, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:15.289 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (fb7cdccc-562f-45a9-b64c-87f7bba4c310, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:19.547 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (909bb7d4-eb9e-4d1d-9b5c-f7fc3a5bf3c1, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:20.221 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (3a0681fb-027b-414a-ab72-8196097bdc68, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:28.367 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (327f5436-b1dc-4748-94f6-8bc0d7dd68c0, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:36.439 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (f4e891ce-05c6-4b46-8061-49b92b71008f, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:43.537 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (327f5436-b1dc-4748-94f6-8bc0d7dd68c0, expected 2e7a90f1-f383-48e8-a9ac-927e61c29ec4)
Jul 25, 2017 21:39:44.017 [0x7f61313ff700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Jul 25, 2017 21:39:44.268 [0x7f6144de8700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Jul 25, 2017 21:39:45.187 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (d68cd9ae-652f-4329-849b-d93b3f80a88a, expected 405f8422-e336-4b4e-a81c-08a3198416c7)
Jul 25, 2017 21:39:45.252 [0x7f6144de8700] WARN - NAT: PMP, got an error: Not Supported by gateway.
Jul 25, 2017 21:39:45.860 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (405f8422-e336-4b4e-a81c-08a3198416c7, expected 092b5b55-d517-452d-8bb3-42342e1290b9)
Jul 25, 2017 21:39:52.284 [0x7f61357ff700] WARN - PubSub: Received notifyConnectivity event with incorrect async identifier (cd399566-782b-4566-8add-c1cd088fa8be, expected 0b020c12-6408-4a50-8e2e-3be218e0d8c8)
Jul 25, 2017 21:39:52.305 [0x7f6145ffd700] WARN - NAT: PMP, got an error: Not Supported by gateway.
You can see PMS thinks it’s sending out requests but nothing is coming back. This is implying something nuts with networking.
Are you using Jumbo packets? Plex Relay, which is available, is the only mechanism which works when jumbos are in use.
Lastly, if you’re command line savvy, I am willing to hand-craft a Preferences.xmlfile for you based on your current one.
This would mean you send me yours in PM, including the desired manual external forwarded port you are using. I will edit the file to reflect this and convince PMS it does not need to hunt for the connection at start. It may flash / be red during until it settles but with a few ‘retries’ (about 30 seconds apart), it will ‘lock in’. Once locked in, it will stay. It is made permanent by letting it stay active (without touching) for a full “Plex.tv connectivity test” cycle (about 30 minutes) before shutting down PMS through the normal systemctl daemon.
