Remote Control Rewind/Fast Forward not working as expected
Remote control Fast Forward and Rewind buttons are no longer functioning as they used to in the new Tizen app preview. Previously, they used to function as true FF/RW scan buttons - press once, video would continue fast-forwarding or rewinding until you pressed play again.
Now they appear to only function as jump forward/back 30-seconds. Which means multiple presses to move through the video. Scrolling through the video by dragging the dot on the progress bar is also more inconvenient than the old behaviour as you have to keep the arrow buttons held down - not really suitable for long videos.
Samsung 2016 UA40KU6000W
Server Version#: 1.20.1.3252
Player Version#: 5.2.1
Update - not sure if this has recently changed again, but I’ve now noticed I can’t fast-forward or rewind at all.
  • As previously mentioned, the fast-forward and rewind buttons have stopped functioning as they should, but could still at least be used to scrub through the seek bar
  • It now appears this function doesn’t work either. Either pressing the buttons once, or holding down, the dot on the seek bar moves back/forward, but then just keeps playing from the same place again
  • Navigating to the seek bar and pressing/holding the arrow buttons on the remote control to drag forward/back also doesn’t work. Again, the seek bar moves, but content plays from the same place.
With all 3 options not working, I now have no way to fast-forward/rewind through a video
Samsung 2016 KS8000
Server Version#: 1.20.1.3600
Player Version#: 5.4.2 ( Platform Version 2.4 )
Tizen Version#: 1242
Hi Plex
Is this issue getting any attention / priority ? It’s been a problem for a long time now and it’s immensely frustrating
Ta
Also the playbutton on the remote doesnt seem to wiork anymore… 5.6.1 for Tizen 2.4
EDIT: Ignore this… fixed itself after a cold restart of the TV
I recommend commenting / keeping an eye on this thread as it seems to be getting marginally more attention
