Server Version#: 1.19.3.2740
Player Version#:8.0.1.17411
Fairly recently I have been having issues playing back content remotely - both on the Shield as well as on my phone (Samsung Note 10). I have remote streaming set to maximum and “automatically adjust quality” enabled. I am noticing that in the dashboard, the playback shows direct play at 9Mbps but the playback will freeze up very frequently. Additionally, the dashboard playback status changes from “playing” to “paused” without anyone pausing it on their own. My internet speed at home is ~1400Mbps down and 42Mbps up and the devices I am trying to play on remotely have good speeds as well (phone average is around 50-75Mbps and the shield is hard wired on Comcast 250Mbps package.
If I manually force the quality to "Convert to 720p HD High 4Mbps) it will play back without a hitch it seems. Remote access shows that plex is fully accessible outside my network.
For what its worth, Tautulli is setup to alert me to certain things such as the server being down, errors etc and I have gotten a LOT of alerts lately about the transcode decision changing and playback sessions pausing/resuming (automatically) around the same time.
So if I force original quality, direct play pauses/stops on its own, convert automatically pauses/stops on its own, forcing to 720p 4Mbps seems to work perfectly all day long. My gateway running Unifi OS takes snapshots of speed tests and I am consistently above 40Mbps for the upload.
Things I have tried -
-Rebooting modem, gateway, switches, APs.
-installing all available Windows updates, Plex updates, and restarting the server.
-changing the port in use
-disabling the firewall and all AV software
-disabling all intrusion prevention systems in the gateway temporarily
It all works flawlessly internally. I’m tempted to try setting up a VPN and accessing it remotely to see if that works. I wouldn’t think Comcast would be doing anything to limit streaming/upload but I can’t say for sure. These issues did start when people started working from home more with the stay at home orders. I did a fresh reboot, opened plex and played back something remotely on my phone set to convert automatically - it kept starting and stopping on its own, and the dashboard showed that playback was paused then would start on its own. I downloaded logs right after that so I tried to isolate 2-3 mins of activity to make it easier to sift through but I still have no idea what I’m looking at. I did see though it has somewhat private into so I would prefer to not post them on the forums but send them to support directly if possible?
Thanks for any suggestions, feedback and help you can provide!
