Remote Stream is using Relay (Indirect) Why?
was working fine but since yesterday When someone is remote stream from my Server
it will use the Relay (Indirect) why ?
Im using Plex server on desktop PC using windows 10
Plex media server is updated to the Latest version
Here is some pictures
If you’re configuring a manual port forward with a custom external port you need to configure the PMS remote access settings accordingly by checking Manually specify public port and enter the same external port you used for the manual port forward.
Generally, PMS using an indirect connection means the client was not able to establish a direct connection to the server and depends on going through a relay server of Plex.
Could be vpn.
