I want to completely remove all subtitles downloaded by the opensubtitles agent since a lot of them are wrong and I have no control over the subtitles the way they are stored. Now when Plextools does what I want (store sub with video, manual download as well as automatic) I want to clean up the mess I have with subtitles.
Any ideas how to do this?
Skickat från min GT-I9505 via Tapatalk
I would also like to do this.
+1
Can some one answer this?
Seems to be hard. Subtitles and links to subtitles are all “hidden” in non readable filenames.
You should be able to remove metadata from agents by turning them off and rescan your library.
If this work I could kiss you
I will try this. Thanks for the tip.
Did this work?
Sendt fra min Nexus 7 med Tapatalk
Yes. Seemed to work. TV Shows which had subtitles was now without subs.
