Remove/disable Remote Access disabled icon?
Server Version#: 1.32.3.7162
Player Version#: N/A
I know it’s a weird little thing, but Is there any way to disable the little red icon next to the “Remote Access” section in the settings if you are not using that feature? I’m using Tailscale for remote access so I have zero need for this feature.
Unfortunately, those of us with OCD tendencies also suffer.
It can’t be turned off.
(you should see a game I play. The devs put red dots on everything you can enable/improve/upgrade. ALL my stuff is marked with red dots. :scream: lol)
