Hi all…
When I go to my plex server, I’m presented with “users” from which to select… I’ve looked but can’t figure out where to delete a user/profile no longer wanted.
please help this “lost” child ![]()
G
Hi all…
G
These users are the members of your Plex Home.
https://support.plex.tv/articles/categories/features/plex-home/
Settings - Plex Home
They can be either “managed” users (they can only be removed from Home by deleting them),
or full plex.tv accounts which have been invited to the Plex Home (these can be ousted from your Home).
If you want to keep some of these users but don’t want to select a user every time the client is started, go into its settings and activate “automatic logon”.
(only the Plex Home admin can set that preference)
ok… makes sense, what i’m expecting, but where do I delete them.
I log in as myself which is the main owner of the system, can’t find a location where I see them and option to delete.
G
I mentioned it above.
And there is a link to the documentation, which also mentions it.
Take another look at the user list, which appears at the start.
Is it your name that has the little “crown” icon on it? That is the Plex Home admin, and only that user can remove or add users.
If the crown is not on your own user name, then you may have joined another plex user’s Home. You can leave this Plex Home at the same place: Settings - Plex Home.
You best use the hosted web app to do these changes.
yes on crown. ![]()
G
sweet, 2 users deleted… really think that cross should rather read delete… 2 cent worth.
thanks
G
