I have a large collection of movies in my Plex Media Server and in the past I had to match some of them manually in Plex cause of the non-perfect fit of file name. Since I spent hours to do that, I’d like to rename the files in local with the correct names to be able to rescan my library again, withouth doing that manually matching, and also to have the correct name files on my PC.
Since the “link” between the file and metadata on Plex already exist, it should not to be so difficult to implement this kind of operation (that is, in fact, just the opposite of what Plex do when you add new contents).
I suggest eventually to let the user choice which metadata to export, compatibly with the file.
Thank you
