I had to fix a bunch of movie titles in my library. I copied them out to my computer, did changes, then deleted the originals in Plex and copied the fixed files over. Somehow that process messed up my library.
When I’m in the Library I get a black screen with:
“Something Went Wrong. An Unexpected Error Occurred.”
The other tabs like, Recommend, Collections, Playlists don’t have this issue. My other libraries (TV) are also fine. It’s just the Movies one. I’ve tried scanning. Restarting the server. Deleting the newly added titles. Clearing cache, and nothing helps. My Backups folder was empty, even though it’s set up in the dashboard (don’t know what went wrong there)
I was going to try and follow the Repair a Corrupted Database article (it’s for desktop plex libraries, not Shield). I copied the database files to my computer and would move them back after the repair, but the article isn’t specific on how to open the database with SQLite.
My media is in a hard drive enclosure connected to the Nvidia Shield Pro via USB. I can access the drives from my computer via ethernet.
What further info would anyone need for me to post, to help with this? Logs?
Thanks in advance
Server Version#:1.43.0.10467
Player Version#:10.30.8.4222
