Repeating an individual song does not work
Server Version#: Version 1.28.1.6041 (64-bit)
Player Version#: 8.7.3
iOS#: 16 beta 7
There appears to be a similar issue to the recently fixed Plex player crash which was fixed as per…
Though the above is fixed on my devices, when playing a single song and setting it to Repeat All or One, once the song finishes it just stops if the screen on the device is off or Plex has been closed and doing something else on the device (i.e. background music playback).
Going back into Plex the song is still there and can be replayed but the same issue occurs above if the screen is off. In PMS the song is sitting there in the now playing dashboard (but not playing).
Steps:
  1. open the Plex player on the device (iPhone or iPad)
  2. select a song
  3. click on the menu item between the queue (on the left) and the 3 dot menu (on the right)
  4. Toggle the Repeat options by tapping on the None entry (which is the default)…set it to One
  5. Start the song playing and then turn off the screen or just close Plex and do something else on the device
Please let me know if there specific logs need and I can DM them.
I just tested this and it seems to be working as expected (repeating the same song all over).
That being said I’m on the stable / non-beta version of iOS (iOS 15.x) with the latest Test Flight preview of the Plex iOS client app (version 8.8). So this working for me might be related to a bug already having been fixed in Plex 8.8 or the issue being specific to the iOS 16 beta
Thanks so much for the quick reply @tom80H :smiley:
I will try with one of my family’s devices as they are not on the beta iOS, but are on the recent Plex app, to see if I see a different behavior.
I tried my wife’s iPhone, which is using iOS 15.6.1 and Plex 8.7.3, and has the same behavior. So it looks like the bug might already be fixed in the next Plex release :slight_smile:
So I decided to install the Test Flight 8.8 version of Plex and noticed a couple of things…
  • the repeat does indeed work as expected
  • after the first run of the song the dialog on the lock screen is empty (music still plays/repeats)
  • opening the player in the control panel (swipe down from the right) shows “not playing” even though the music is playing
plex_music_app
  • open Plex and the song is there and playing but close Plex and it crashes again
Note:
I did this on a freshly restored iPad running 15.6.1 (latest non-beta version)
